[GRASS-dev] Modules
Moritz Lennert
mlennert at club.worldonline.be
Sat Feb 24 02:24:19 EST 2007
On Fri, February 23, 2007 20:15, Glynn Clements wrote:
> Moritz Lennert wrote:
>> >> The remaining step is to reinstate the bgcmd= option.
>> > Done; updated patch (again, against CVS HEAD) attached.
>> I know this is a bit off-topic, but I'm having trouble applying this
>> patch. The way I understand the -p option of patch, if I am within the
>> grass6 directory, I have to use 'patch -p3 < changes.diff'
> Use:
> cd vector/v.digit
> patch -p0 < changes.diff
> Normally, I create patches from the top-level directory, so you need
> "patch -p0" from the top-level directory. In this case, the patches
> were created from the v.digit directory, so you need "patch -p0" from
> the v.digit directory.
> Essentially, the -p switch indicates the number of leading components
> to strip from the pathnames in the --- and +++ lines (the lines before
> those aren't significant to "patch").
> You only need a non-zero argument to -p if you are applying a patch
> from beneath the point where the patch was created. If you are above
> that point, you need to cd down into the correct directory.
Ok. Thanks. Now I know what I got wrong: I took
RCS file: /grassrepository/grass6/vector/v.digit/attr.c,v
as reference, not
Index: attr.c
Everything I've tested works great so far !
Moritz
