[GRASS-dev] [grass-code R][288] Ability to treat CELL maps as FCELL
in r.report
grass-coder at wald.intevation.org
Tue Feb 13 03:54:31 EST 2007
code R item #288, was opened at 2007-02-13 10:54
Status: Open
Priority: 3
Submitted By: Māris Nartišs (marisn)
Assigned to: Nobody (None)
Summary: Ability to treat CELL maps as FCELL in r.report
Issue status: None
GRASS component: raster
Operating system: Linux
Operating system version:
Initial Comment:
If I run r.report on CELL map that contains many categroties (i.e. elevation.dem at PERMANENT in Spearfish), it will report stats about ALL categories in map and there is no option to use grouping like for fp maps. It would be nice to have switch "Use CELL map as FCELL" thus allowing to get meaningfull reports from r.report on maps like elevation.dem.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=188&aid=288&group_id=21
