[GRASS-dev] [grass-code R][313] v.digit: OK button for Settings window
grass-coder at wald.intevation.org grass-coder at wald.intevation.org
Sun Feb 25 03:34:12 EST 2007
code R item #313, was opened at 2007-02-25 09:34
Status: Open
Priority: 3
Submitted By: Markus Neteler (markusn)
Assigned to: Nobody (None)
Summary: v.digit: OK button for Settings window
Issue status: None
GRASS component: vector
Operating system: all
Operating system version:
Initial Comment:
A close ("OK") button for the entire window or something reasonable
is desired for the "Settings" window.
Take for example the "Background" tab:
- click "Add command"
- write "Winnie The Pooh"
- then? Kill the entire settings window - not really obvious
("Winnie The Pooh" is then silently ignored/disappears)
I would expect some "OK" button below all tabs which does
apply changes and close window.
thanks,
Markus
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=188&aid=313&group_id=21
