Glynn Clements wrote: > > Tcl knows when a process finishes by the "eof" from the stream > identifier which "open |..." returns. There's no reason why the Tcl/Tk > GUI can't add something to the gronsole when the command has finished, > regardless of whether or not the module uses G_done_message(). then let's do it! Hamish
