[GRASS-dev] [grass-code I][315] r.proj(.seg) overwrites when no
	output given
    grass-codei at wald.intevation.org
    Mon Feb 26 19:16:53 EST 2007
code I item #315, was opened at 2007-02-26 18:16
Status: Open
Priority: 3
Submitted By: William Kyngesburye (kyngchaos)
Assigned to: Nobody (None)
Summary: r.proj(.seg) overwrites when no output given
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: raster
Operating system: MacOS X
Operating system version: 10.4
GRASS CVS checkout date, if applies (YYMMDD): 070220
Initial Comment:
if no output name is given in r.proj (and r.proj.seg), so that it defaults to the same name as the input raster, and that raster exists in the current mapset, no existing raster warning is given and the existing one is overwritten.
If an output is given that's the same as the input, and it exists in the current mapset, the warning does come up as expected.
ie:
locll/data/dem - a latlong raster
locproj/data/dem - a projected raster
current loc/mapset: locproj/data
This trashes locproj/data/dem with no warning:
> r.proj loc=locll map=data in=dem
This gives warning as expected:
> r.proj loc=locll map=data in=dem out=dem
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=315&group_id=21
