[GRASS-dev] r3.univar and r.univar
Daniel Calvelo
dca.gis at gmail.com
Tue Feb 27 14:09:14 EST 2007
On 2/27/07, Sören Gebbert <soerengebbert at gmx.de> wrote:
> The heapsort functions are located in a separate file
> including a note which references the german wikipedia site.
> Im not sure if i can use this code in a GPL software?
AFAICT you can, but the code itself is GFDL-licensed by the Wikipedia
article author. You could alternatively use GSL's heapsort which is
GPLed:
http://sourceware.org/cgi-bin/cvsweb.cgi/gsl/sort/sortvec.c?rev=1.5&content-type=text/x-cvsweb-markup&cvsroot=gsl
BTW I found that using code.google.com and searching for 'heapsort license:gpl'
Daniel.
-- Daniel Calvelo Aros
