[GRASS-dev] winGRASS: debugging vector db issues
Glynn Clements
glynn at gclements.plus.com
Tue Feb 27 15:10:57 EST 2007
Moritz Lennert wrote:
> > which probably explains why it works when compiled statically. But then
> > all parts of GRASS should be linking against $(FMODE_OBJ) - perhaps
> > parts of the database drivers aren't though? Will hopefully have time to
> > look into it later.
> AFAICT, all the db/drivers do, but not the db libs:
> mlennert at geog-pc40:~/SRC/GRASS/CVS/grass6/lib/db$ grep -RI FMODE_OBJ *
> Should they ?
There's no point adding it to a library; it has to go into the
executable.
