[GRASS-dev] [grass-code R][317] Put titles closer to check boxes
grass-coder at wald.intevation.org
Tue Feb 27 15:20:09 EST 2007
code R item #317, was opened at 2007-02-27 21:20
Status: Open
Priority: 3
Submitted By: Carlos Dávila (carluti)
Assigned to: Nobody (None)
Summary: Put titles closer to check boxes
Issue status: None
GRASS component: gis.m
Operating system: Linux
Operating system version: debian etch
Initial Comment:
The display section of gis.m for vector maps has two lines with lists of items to display, each one with a check box. Check boxes are at the same distance from their own item and previous one so it's a little confusing to know which one belongs to which one. It would be easier if check boxes are closer to their one item.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=188&aid=317&group_id=21
