[GRASS-dev] DBMI parse error question
Markus Neteler neteler at itc.it
Tue Feb 27 17:38:01 EST 2007
I try to import a map from PostgreSQL into GRASS/DBF driver
with v.in.db, but get
DBMI-DBF driver error:
SQL parser error in statement:
create table ticks_feltre_2002_2006_sites ( ID integer, comune varchar(250), localita varchar(250), microsito varchar(250), data date, ora time, larve integer, ninfe integer, adm integer, adf integer, adtot integer, tcelsius double precision, umidrel double precision, note varchar(250), mapsheet varchar(250), mgrs varchar(250), stazione varchar(250), periodo_prelievo varchar(250), north double precision, east double precision, siteid integer )
Cannot create table
but I don't see where the evil is:
echo " ID integer, comune varchar(250), localita varchar(250), microsito varchar(250), data date, ora time, larve integer, ninfe integer, adm integer, adf integer, adtot integer, tcelsius double precision, umidrel double precision, note varchar(250), mapsheet varchar(250), mgrs varchar(250), stazione varchar(250), periodo_prelievo varchar(250), north double precision, east double precision, siteid integer" | tr -s ',' '\n' | sort
 adf integer
 adm integer
 adtot integer
 comune varchar(250)
 data date
 ID integer
 larve integer
 mgrs varchar(250)
 ninfe integer
 note varchar(250)
 ora time
 siteid integer
Any ideas? Of course it would be fancy to have a more reasonable
error message. This error uses to pop up if preserved words are used
as column names, but I don't see any (even, it should tell me in an
ideal world).
Markus
