[GRASS-dev] r3.univar and r.univar
Sören Gebbert
soerengebbert at gmx.de
Tue Feb 27 19:17:01 EST 2007
i dont have a copy of this book. :(
And i did not found the code in the net.
Best regards
Soeren
tlaronde at polynum.com schrieb:
> Sören Gebbert wrote:
>> Important note:
>> I have used a heapsort algorithm based on code from the german
>> wikipedia:
>> http://de.wikipedia.org/wiki/Heapsort
>> The heapsort functions are located in a separate file
>> including a note which references the german wikipedia site.
>> Im not sure if i can use this code in a GPL software?
> Why don't you use the heapsort algorithm from Donald E. Knuth,
> "Sorting and Searching", TAOCP volume 3, 2nd edition, Addison-Wesley,
> Algorithm H p 144-158.
> You will be safe on the licence side.
