[GRASS-dev] g.list -a
Martin Landa landa.martin at gmail.com
Thu Jan 4 05:47:02 EST 2007
it is nice idea but there is one problem. The data type list is common
for related modules, e.g. g.remove, g.copy, etc. It would affect them
also...
Martin
2007/1/3, Daniel Calvelo <dca.gis at gmail.com>:
> How about g.list type=any or g.list type=all?
> 2c.
> On 12/28/06, Martin Landa <landa.martin at gmail.com> wrote:
> > Hi,
> > I have just one general (maybe a little bit silly;-) question. There
> > are number of modules which follow this pattern:
> > * there is one (determinative) parameter (e.g. type in g.list)
> > * and the flag for all types (e.g. -a -- List all data types)
> > I can see two distinct approaches:
> > 1) the determinative parameter is requested
> > -> usage: g.list -a type=
> > This is more precise for parsing syntax of the module, I think. On the
> > other hand a little bit confusing for the user.
> > 2) the determinative parameter is not requested
> > -> usage: g.list -a
> > This construction is more clear for the user I hope. But it cause more
> > problems for programmer -- there is a need to handle meaningless usage
> > of the module, e.g. g.list -f (verbose listing).
> > I am not sure which approach is better.
> > Best regards, Martin
> > 2006/12/27, Martin Landa <landa.martin at gmail.com>:
> > > Hi,
> > > 2006/12/27, Glynn Clements <glynn at gclements.plus.com>:
> > > > Martin Landa wrote:
> > > > > > > I am trying to implement the wish [1]. I found a strange construction
> > > > > > > in g.list module. The -f flag (full listing) calls the external
> > > > > > > program $GISBASE/etc/lister/[cell|vector]. These little programs are
> > > > > > > called only in g.list -f (I think).
> > > > > > > I rewrote g.list without calling any external program -- i.e. I moved
> > > > > > > functions from lister directory to lib/lister.c. If there are no
> > > > > > > serious objections I will commit it to CVS.
> > > > > > Don't remove the existing functionality; add a new switch for using
> > > > > > your built-in lister.
> > > > > this patch does not remove any functionality (AFAIK). The only change
> > > > > is: the functionality of lister (programs) is moved to lib/lister.c. I
> > > > > don't see any reason why to have this functionality (the -f flag)
> > > > > outside of the g.list (/etc/lister/[cell|vector]). Maybe there is a
> > > > > particular reason for this construction, please let me know. Thanks!
> > > > The user can install lister programs for other types and/or replace
> > > > existing ones.
> > > OK, it makes sense to me (only it's hard to imagine an user how
> > > installs other lister program instead of changing the code;-)
> > > > The point of -f isn't so much to provide specific additional
> > > > functionality, but to allow the handling to be deferred to an external
> > > > program.
> > > You are right, I have tried to change the patch in this way, not sure
> > > if I am working with child process as I should have. In any case
> > > g.list works:-)
> > > Martin
> > > Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
> -- Daniel Calvelo Aros
