[GRASS-dev] g.region print flags combination
Martin Landa landa.martin at gmail.com
Fri Jan 5 08:37:54 EST 2007
2007/1/5, Glynn Clements <glynn at gclements.plus.com>:
> > 3) The -p flag was changed.
> > projection: 99 (Krovak)
> > zone: 0
> > datum: towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56
> > projection : 99 (Krovak)
> > zone       : 0
> > datum      : towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56
> > Not sure what formatting is more appropriate.
> Personally, I would have added the padding after the colons, i.e.:
> zone:        0
> The reason being that a regexp such as "^([^:]*): *(.*)$" would still
> work as before.
OK, changed in CVS. Thanks!
Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
