[GRASS-dev] GRASS startup window patches
Glynn Clements
glynn at gclements.plus.com
Sat Jan 6 00:18:24 EST 2007
Paul Kelly wrote:
> As we saw in the discussions about g.region and gis.m, using the Tcl catch
> commands on GRASS commands isn't generally a good idea
On the contrary, most exec (and "open |...") commands *should* use
catch so that errors (either real errors or Tcl complaining about
stderr) aren't fatal.
> as Tcl falsely
> assumes a command that writes to stderr is issuing an error. This applies
> to g.proj too. If partially-specified datum information is passed to
> g.proj, it WILL try to interactively prompt the user for complete
> information. This is done by printing to stderr and looking for an input
> on stdin.(The Tcl catch command will treat this as an error.) There are
> also circumstances where g.proj will issue a warning (but still proceed to
> create the location OK), and again this writes to stderr and the catch
> command will erroneously assume there is an error.
No, it's exec which treats it as an error; the catch command catches
the exception which exec throws so that it doesn't terminate the
program.
> I think, until we can work out some way of always passing fully specified
> datum information to g.proj, that when g.proj is used for location set-up
> we should run it in a pop-up terminal Window. So if it does choose to
> prompt the user it (while kludgy and archaic-looking) will actually work.
What is the problem with simply removing the "interactive" parameter
from GPJ_{osr,wkt}_to_grass()?
