[GRASS-dev] i.image.mosaic/i.landsat.rgb
Daniel Calvelo
dca.gis at gmail.com
Sun Jan 7 21:38:39 EST 2007
Brad,
Try this version.
Daniel.
On 1/7/07, Brad Douglas <rez at touchofmadness.com> wrote:
> Hello,
> i.image.mosaic errors out with the following:
> GRASS 6.3.cvs (black_rock):~ > i.image.mosaic image1=etm1.1
> image2=etm2.1 image3=etm3.1
> ATTENTION: Do not forget to set region properly to cover all images!
> i.image.mosaic: line 85: [: argument expected
> i.image.mosaic: line 106: [: argument expected
> i.image.mosaic: line 119: [: too many arguments
> With i.landsat.rgb, I get a bit farther, but produces a blank display.
> I'm quite certain that is not a desirable feature. :-)
> Could a good shell scripter take a look?
> Brad Douglas <rez touchofmadness com> KB8UYR/6
> Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
-- Daniel Calvelo Aros
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070107/99f46b1e/i.image.obj
