[GRASS-dev] g.list -a
Glynn Clements
glynn at gclements.plus.com
Sat Jan 13 12:57:03 EST 2007
Martin Landa wrote:
> > + if (G_parser(argc, argv))
> > + fprintf (stderr, _("\nWhere %s is one of:\n"), element->key);
> > + show_elements();
> > + exit(EXIT_FAILURE);
> > If G_parser() fails, the program should just call exit(EXIT_FAILURE);
> > G_parser() will print an error message detailing why it failed.
> Yes, but the function show_elements() provides the user additional
> information why it failed. Would you like to remove it (maybe I have
> missed something)?
> Where type is one of:
> rast (raster files)
> rast3d (raster3D files)
> vect (binary vector files)
> oldvect (old (GRASS 5.0) binary vector files)
> asciivect (ascii vector files)
> icon (paint icon files)
> labels (paint label files)
> sites (site list files)
> region (region definition files)
> region3d (region3D definition files)
> group (imagery group files)
> 3dview (3D view parameters)
The built-in error handling will display the following message:
Error: value <foo> out of range for parameter <type>
Legal range: rast,rast3d,vect,oldvect,asciivect,icon,labels,sites,region,region3d,group,3dview
IMHO, this is sufficient. Note that the type descriptions *aren't*
shown if you use "g.list help", only if there is a parsing error
(which isn't limited to an invalid value for the type= option).
OTOH, I'm not really that bothered about this issue; assuming that it
compiles okay, I'll commit your latest version.
> > > > lib/do_list.c doesn't need to change; just have cmd/list.c call
> > > > do_list() once for each type.
> > > I think that fn do_list() have to be rewritten because of the -f flags
> > > (calling of execl() fn) ?
> > No; do_list() can remain untouched, while the handling of -f should
> > remain essentially the same, except that it should use G_spawn()
> > instead of execl().
> Ops, you are right. Maybe I need study GRASS API more deeply:-) Thanks
> for pointing to the G_spawn! Now it works.
FWIW, I've added a native Windows version of G_spawn(), although I
haven't had chance to test it yet.
