[GRASS-dev] new r.out.gdal fails to preserve 8bit color
Moritz Lennert mlennert at club.worldonline.be
Wed Jan 17 03:23:25 EST 2007
On 16/01/07 22:14, Markus Neteler wrote:
> On Tue, Jan 16, 2007 at 09:53:41PM +0100, Markus Neteler wrote:
>>>> Vytautas,
>>>> Exporting a CELL GRASS raster, value range 0-255, r.out.gdal issues an:
>>>> ERROR 6: SetColorInterpretation() not supported for this dataset.
>>>> and the output map is greyscale.
>>> There is a discussion about this defect on the GDAL dev list:
>>> http://www.nabble.com/r.out.gdal%3A-SetColorInterpretation%28%29-not-supported-tf3021127.html
>> Probably the mapgdal.c file of MapServer could be an inspiration?
> I found some more:
> http://www.nabble.com/Re:-How-to-set-a-ColorTable-from-scratch--p5000321.html
> http://www.archivesat.com/FreeGIS_project/thread1933209.htm
> and GDAL
> apps/gdalwarpsimple.c
> Still lost :-)
In the very first thread, Frank says:
"Generally speaking to produce a GeoTIFF file with a color table after
using Create() to create it, you need to do the SetColorTable() *before*
writing any raster data."
I don't see any call to SetColorTable in main.c of r.out.gdal. Could
this be the problem ?
Moritz
