[GRASS-dev] Re: [Gdal-dev] GDAL/OGR 1.4.0 Released
Markus Neteler neteler at itc.it
Wed Jan 17 10:39:56 EST 2007
OK.
configure:2939: checking for G_asprintf in -lgrass_gis
configure:2969: gcc -o conftest -O2    conftest.c -lgrass_gis -L/usr/local/grass-6.3.cvs/lib -lgrass_I -lgrass_vask -lgrass_gmath -lgrass_gis -lgrass_datetime -lgrass_gproj -lgrass_vect -lgrass_dbmibase -lgrass_dbmiclient -lgrass_dgl -lgrass_dig2 -lgrass_rtree -lgrass_linkm -L/usr/local/lib -lgdal  >&5
/usr/local/lib/libgeos_c.so.1: undefined reference to `geos::WKBReader::read(std::basic_istream<char, std::char_traits<char> >&)'
/usr/local/lib/libgeos_c.so.1: undefined reference to `geos::WKBWriter::write(geos::Geometry const&, std::basic_ostream<char, std::char_traits<char> >&)'
/usr/local/lib/libgeos_c.so.1: undefined reference to `geos::Point::getCoordinatesRO() const'
/usr/local/lib/libgeos_c.so.1: undefined reference to `geos::WKBWriter::WKBWriter(int, int)'
collect2: ld returned 1 exit status
What does
  ldd /usr/local/grass-6.3.cvs/lib/*6.3.cvs*.so
say?
I assume that geos slips in through libgdal. BTW: Mine points to
        libgeos.so.2 => /usr/local/lib/libgeos.so.2 (0x0000002a95c03000)
        libgeos_c.so.1 => /usr/local/lib/libgeos_c.so.1 (0x0000002a95e0f000)
Is it possible that your GEOS is a bit old? Or that you have two
GEOS libs in parallel?
Just guessing,
Markus
On Wed, Jan 17, 2007 at 04:34:30PM +0100, Maciej Sieczka wrote:
> Markus Neteler wrote:
> > Can you send the config.log file?
> Sure. It's already here:
> http://www.nabble.com/attachment/8115821/0/config.log.bz2
> Paul already looked into it:
> http://www.nabble.com/gdal-grass-plugin-fails-during-.-configure-with-GRASS-6.3-CVS-tf2904798.html#a8115502
> Maciek
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
