[GRASS-dev] new r.out.gdal fails to preserve 8bit color
Wed Jan 17 15:47:39 EST 2007
Markus Neteler wrote:
> > Right now I have submitted related code based on the GRASS-GDAL plugin.
> > It now creates color rules, but the color interpretation is still
> > wrong (gray instead of RGB).
> > Please someone may revisit it.
> It appears that G_get_f_color_rule() doesn't return what it should. No
> clue how to fix it.
I've only tested it briefly, but it seems fine to me. Can you explain
what you think is wrong?
