[GRASS-dev] new r.out.gdal fails to preserve 8bit color
Glynn Clements
glynn at gclements.plus.com
Fri Jan 19 10:31:42 EST 2007
Markus Neteler wrote:
> > Why do you think that this is an issue with G_get_f_color_rule()?
> Maybe that's a wrong assumption.
> > With a simple test program, I get results which exactly match the
> > contents of the colr file.
> I tried on two machines. The exported file does not contains colors. I wonder
> if you get a colored output file (did you try a Spearfish raster map?).
I haven't looked into the overall issue of colour tables in r.out.gdal
(I'm entirely unfamiliar with the GDAL API), only the question of
whether G_get_f_color_rule() works correctly (it appears to).
