[GRASS-dev] File based GRASS batch processing?
Markus Neteler
neteler at itc.it
Mon Jan 22 18:13:16 EST 2007
On Tue, Jan 23, 2007 at 12:10:20AM +0100, Markus Neteler wrote:
> Attached a first sort of working hack "diff". Could be
> certainly nicer.
Sorry, this one I wanted to send.
Markus
Index: init.sh
RCS file: /home/grass/grassrepository/grass6/lib/init/init.sh,v
retrieving revision 1.99
diff -u -r1.99 init.sh
--- init.sh 8 Jan 2007 15:22:24 -0000 1.99
+++ init.sh 22 Jan 2007 23:12:00 -0000
@@ -90,6 +90,7 @@
echo " GRASS_WISH set wish shell name to override 'wish'"
echo " GRASS_HTML_BROWSER set html web browser for help pages"
echo " GRASS_ADDON_PATH set additional path(s) to local GRASS modules"
+ echo " GRASS_BATCH_JOB shell script to be processed as batch job"
exit
@@ -665,6 +666,16 @@
exit 1
fi
+# hack to process batch jobs:
+if [ -x "$GRASS_BATCH_JOB" ] ; then
+ if [ ! -f "$GRASS_BATCH_JOB" ] ; then
+ echo "Batch job file $GRASS_BATCH_JOB as defined in GRASS_BATCH_JOB variable not found. Exiting."
+ exit 1
+ else
+ SHELL="$GRASS_BATCH_JOB"
+ fi
+fi
# Start the chosen GUI but ignore text
case "$GRASS_GUI" in
@@ -866,3 +877,8 @@
echo
echo "Goodbye from GRASS GIS"
echo
+ echo "Batch job $GRASS_BATCH_JOB was executed."
+ exit 0
+fi
