[bug #3041] [GRASS-dev] nviz export PPM
Hamish
hamish_nospam at yahoo.com
Thu Jan 25 22:57:59 EST 2007
Brad Douglas wrote:
> The export to high-resolution PPM in nviz is broken. Exported images
> either alternate between good and garbage pieces, or it gets to a
> point and the rest of the image is garbage.
bug #3041
https://intevation.de/rt/webrt?serial_num=3041
> I currently have no repository to post data and images, but I can
> email to anyone who wants to take a look.
The new gforge bug tracker will take image uploads.
flickr.com is another place to post them.
With the current grass 6.3-cvs I get this error when I try the menu item:
Error: no files matched glob pattern "*"
while executing
"glob -directory $cur_dir *"
(procedure "refresh_file_browser" line 10)
invoked from within
"refresh_file_browser $w"
(procedure "create_file_browser" line 91)
invoked from within
"create_file_browser .file_browser 1"
invoked from within
".top.menu.file.m.img invoke active"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke active]"
(procedure "tkMenuInvoke" line 47)
invoked from within
"tkMenuInvoke .top.menu.file.m.img 1
(command bound to event)
after clicking [Ok] I get a file browser, but it doesn't build and image.
For me it works fine with GRASS 6.2.1 on my Debian/Sarge & 32bit Pentium4.
Hamish
