[GRASS-dev] File based GRASS batch processing?
Dylan Beaudette debeaudette at ucdavis.edu
Mon Jan 22 13:27:45 EST 2007
On Monday 22 January 2007 08:09, Markus Neteler wrote:
> Hi,
> I often have to process large data sets on remote
> machines which takes more than a day. Since I
> cannot keep the ssh connection open for so long,
> it would be very convenient to have the possibility
> to pass a file (containing GRASS commands) as
> parameter to the startup script, say something like:
> nohup grass63 -text -batch myjobs.sh ~/grassdata/spearfish60/neteler/ &
> I assume that this would require changes in lib/init/init.*
> (maybe for now only lib/init/init.sh).
> Before wasting time on this, any suggestions for a best
> implementation? Maybe I am overlooking an easy solution.
> Markus
Hi Markus,
It has been mentioned once already by Stephan, but I too would highly
recommend screen. I use this routinely for large GRASS jobs on remote
machines via ssh. The most important commands can be summarized in a couple
sentences:
ssh remote_machine
screen
grass63 location/mapset
v.surf.rst in=bigfile
<ctrl> + <a> (pause and let up on the previous keys) <d>
(now you are back to the shell on the remote machine)
exit
to reconnect:
ssh remote_machine
screen -r
if you have more than one screen session going, use the session number to
reconnect.
Cheers,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
