[Fwd: Re: [GRASS-dev] r.colors: rules file list unsorted]
Wolf Bergenheim wolf+grass at bergenheim.net
Sun Jan 28 15:37:48 EST 2007
ok to commit the attached diff?
It uses scandir() to sort the directory entries alphabetically. I'm not
100% sure scandir can be found on all platforms in which case we need to
do something, like qsort() the names list instead.
What do you think?
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
Index: main.c
RCS file: /grassrepository/grass6/raster/r.colors/main.c,v
retrieving revision 2.11
diff -u -r2.11 main.c
--- main.c      17 Oct 2006 11:43:08 -0000      2.11
+++ main.c      28 Jan 2007 20:29:49 -0000
@@ -38,25 +38,26 @@
        int size = 0;
        int len = 0;
        DIR *dir;
+       struct dirent **d;
+       int i,l;
        sprintf(path, "%s/etc/colors", G_gisbase());
-       dir = opendir(path);
-       if (!dir)
+       l = scandir(path, &d, 0, alphasort);
+       if (l < 0)
                return NULL;
-       for (;;)
+       for(i=0;i < l; i++)
-               struct dirent *d = readdir(dir);
                int n;
-               if (!d)
-                       break;
-               if (d->d_name[0] == '.')
+               if (d[i]->d_name[0] == '.')
+                       G_free(d[i]);
                        continue;
-               n = strlen(d->d_name);
+               n = strlen(d[i]->d_name);
                if (size < len + n + 2)
@@ -67,11 +68,11 @@
                if (len > 0)
                        list[len++] = ',';
-               memcpy(&list[len], d->d_name, n + 1);
+               memcpy(&list[len], d[i]->d_name, n + 1);
                len += n;
+               G_free(d[i]);
-       closedir(dir);
+       G_free(d);
        return list;
@@ -91,23 +92,22 @@
        char path[4096];
        DIR *dir;
        int names_len = 0;
-       int i;
+       int i,n;
-       if (!dir)
+       n = scandir(path, &d, 0, alphasort);
+       if (n < 0)
                G_fatal_error("Rules directory doesn't exist");
-       for (;;)
+       for (i=0;i<n;i++)
-               if (!d)
-                       break;
+                       G_free(d[i]);
                        continue;
                if (names_len >= names_size)
@@ -115,12 +115,10 @@
                        names = G_realloc(names, names_size * sizeof(char *));
-               names[names_len++] = G_store(d->d_name);
+               names[names_len++] = G_store(d[i]->d_name);
+               G_free(d[i]);
-       closedir(dir);
-       qsort(names, names_len, sizeof(char *), cmp_names);
+       G_free(d);
        for (i = 0; i < names_len; i++)
