[Fwd: Re: [GRASS-dev] r.colors: rules file list unsorted]
Paul Kelly paul-grass at stjohnspoint.co.uk
Sun Jan 28 17:37:24 EST 2007
On Mon, 29 Jan 2007, Wolf Bergenheim wrote:
>> or another way:  should we keep malloc()+free() separate from
>> G_malloc()+G_free()? ie don't mix the two?
> Isn't G_free just a wrapper for free, so that programmers don't need to worry
> about linking with correct allocation libraries, and including headers which
> vary on some UNIX platforms?
According to the programmers manual:
"The following routines provide memory allocation capability. They are
simply calls to the UNIX suite of memory allocation routines malloc( ),
realloc( ) and calloc( ), except that if ther is not enough memory, they
print a diagnostic message to that effect and then call exit( ).
Note. Use the G_free( ) routine to release memory allocated by these
routines."
So in practice they are the same, but I think it is cleaner programming
and safer in the long run not to mix malloc() with G_free() etc.
Paul
