[GRASS-dev] r.flow: crash on 64bit
Markus Neteler
neteler at itc.it
Mon Jan 29 16:39:18 EST 2007
when using r.flow on 64bit, it crashes (Spearfish example):
r.flow elevation.dem flout=flout lgout=lgout dsout=dsout
Reading input files: elevation
Precomputing: tangents
Precomputing: e/w distances
Precomputing: quantization tolerances
Precomputing: interpolated border elevations
Precomputing: aspects
Calculating maps ...
Segmentation fault
It dies in calc.c:223.
A backtrace:
GRASS 6.3.cvs (spearfish60):~ > gdb `which r.flow`
GNU gdb Red Hat Linux (6.3.0.0-1.132.EL4rh)
This GDB was configured as "x86_64-redhat-linux-gnu"...Using host libthread_db library "/lib64/tls/libthread_db.so.1".
(gdb) r elevation.dem flout=flout lgout=lgout dsout=dsout
Starting program: /nfsmnt/bartok0/ssi/neteler/software/cvsgrass63/dist.x86_64-unknown-linux-gnu/bin/r.flow elevation.dem flout=flout lgout=lgout dsout=dsout
[Thread debugging using libthread_db enabled]
[New Thread 182925195200 (LWP 26627)]
Detaching after fork from child process 26630.
Detaching after fork from child process 26631.
WARNING: The vector 'flout' already exists and will be overwritten.
0%
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 182925195200 (LWP 26627)]
0x0000000000403e3f in next_point (p=0x7fbfffdf20, a=0x7fbfffdf10, b=0x7fbfffdf00, l=0x7fbfffdec0)
at calc.c:223
223 if (oldtheta != 90 && oldtheta != 270 && /* north/south */
(gdb) bt full
#0 0x0000000000403e3f in next_point (p=0x7fbfffdf20, a=0x7fbfffdf10, b=0x7fbfffdf00, l=0x7fbfffdec0)
at calc.c:223
sub = 0
cut = 2.356693130662746e-321
horiz = 2
semi = 1
length = 1.1899763912722237e-312
delta = 0
deltaz = 0
oldz = -nan(0xfffffffffffff)
oldtheta = -2147483648
oldr = 0
oldc = 0
ads = {row = 0, col = 0}
bdy = {-30, 30}
bdx = {-30, 30}
#1 0x0000000000404bb4 in calculate () at calc.c:369
pts = {x = 589995, y = 4927995, z = -nan(0xfffffffffffff), theta = -2147483648, r = 0, c = 0}
bbs = {{-1, 1}, {1, -1}}
fls = {px = 0xc224b0, py = 0xc287e0, index = 1}
row = 0
col = 0
x = 589995
y = 4927995
length = 0
xstep = 30
ystep = 30
lg = (FCELL *) 0xc1f9f0
points = (struct line_pnts *) 0xc1f550
cats = (struct line_cats *) 0xc1f5e0
loopstep = 1
#2 0x0000000000404dd2 in main (argc=5, argv=0x7fbffff288) at calc.c:419
history = {
mapid = "\020�\177\000\000\000\232�0238\000\000\000\000\200i\225*\000\000\000H\205i\225*\000\000\000\210\212i\225*\000\000\000\000`\225*\000\000\000t \227*", '\0' <repeats 11 times>, "@�\177\000\000\000\224�0238\000\000",
title = "\000\000\000\000\000\000\000\000�\177\000\000\000\020�\177\000\000\000n\022\221\225*\000\000\000h\203\225*\000\000\0000�\177\000\000\000\210\212i\225*\000\000\000�226�0238", '\0' <repeats 11 times>, "�\t\000\000\000\000",
mapset = "n\022\221\225*\000\000\000�0238", '\0' <repeats 11 times>, "@X�0238\000\000\000�\177\000\000\000\226�0238\000\000\000\230�\177\000\000\000\220�\177", '\0' <repeats 11 times>, "\002\000\000\000\000\000\000",
creator = "\020�\177\000\000\000\232�0238\000\000\000t \227*", '\0' <repeats 11 times>, "0�\177\000\000\000\210\212i\225*\000\000\000 �\177\000\000\000\224�0238\000\000\000\000\000\000\000\177\000\000\000�{\225*\000\000",
maptype = "\220\225*\000\000\000`�\177\000\000\000H\205i\225*\000\000\000�226�0238", '\0' <repeats 11 times>, "\020�\177\000\000\000�{\225*\000\000\000�0238\000\000\000�031@\000\000\000\000\000 at X�0238\000\000",
datsrc_1 = "�\177\000\000\000\226�0238\000\000\000\230�\177\000\000\000\220�\177\000\000\000@\003", '\0' <repeats 14 times>, "�{\225*\000\000\000\002\000\000\000\000\000\000\000\020�\177\000\000\000\232�0238\000\000",
datsrc_2 = "t \227*", '\0' <repeats 11 times>, "�\177\000\000\000\224�0238", '\0' <repeats 11 times>, "�\177\000\000\000\020�\177\000\000\000�i\225*\000\000\000Xz\225*\000\000\000\220�\177\000\000",
---Type <return> to continue, or q <return> to quit---
keywrd = "\000\200i\225*\000\000\000�226�0238", '\0' <repeats 11 times>, "@A�0238\000\000\000�i\225*\000\000\000�0238\000\000\000\020\000\000\000\000\000\000\000 at X�0238\000\000\000�\177\000\000\000\226�0238\000\000", edlinecnt = -1073746536, edhist = {
"\177\000\000\000\220�\177\000\000\000\022\000\000\000\000\000\004\000\000\000\000\000\000\000\020�\177\000\000\000\232�0238\000\000\000\000`\225*\000\000\000\210\212i\225*\000\000\000t \227*", '\0' <repeats 11 times>, "�",
"\177\000\000\000\224�0238", '\0' <repeats 11 times>, "�002\0248\000\000\000�002\0248\000\000\000�\177\000\000\000\020�\177\000\000\000\r�\225*\000\000\000Hbi\225*\000\000\000�\177\000\000\000\230gU\225",
"*\000\000\000�226�0238", '\0' <repeats 11 times>, " \000\000\000\000\000\000\000\r�\225*\000\000\000�0238\000\000\000\030\022\000\000\000\000\000 at X�0238\000\000\000�\177\000\000\000\226�0238\000\000\000\230�",
"\177\000\000\000\005\000\000\000\000\000\000\000\020�\177\000\000\000\232�0238\000\000\000H\205i\225*\000\000\000\210\212i\225*\000\000\000\000`\225*\000\000\000t \227*", '\0' <repeats 11 times>, "\230gU\225*\000\000\000�",
"\177\000\000\000\224�0238", '\0' <repeats 27 times>, "\b\000\000\000\000\000\000\000R�d\004\000\000\000(\022\000\000\000\000\000(\002\0248\000\000\000\030\002\0248\000\000\000X,\000",
"\000\000\000\000X,\000\000\000\000\000\000 \000\000\000\000\000\000\000\004\000\000\000\020\000\000\000\001\000\000\000GNU\000\000\000\000\000\002\000\000\000\004\000\000\000\024\000\000\000\001\000\000�a\000\000\005\006\000\000!\004\000\000b\a\000\000i\006\000\000\203\a\000",
"j\005\000\000$\000\000\000\000\000\000\000\020�\177\000\000\000\232�0238\000\000\000H\205i\225*\000\000\000\210\212i\225*\000\000\000\000`\225*\000\000\000\000\020�225*\000\000\000H\025�225*\000\000\000Hj\225*\000\000\000\220\032�225",
"*\000\000\000d\225*\000\000\000\000\200i\225*\000\000\000\000\000\225*\000\000\000\004\225*\000\000\000`\t\225*\000\000\000\000P\225\226*\000\000\000T\225\226*\000\000\000hY\225\226*\000\000\000\000\000�226*\000\000\000\004�226",
"*\000\000\000X\t�226*\000\000\000\r�226*\000\000\000\230\022�226*\000\000\0008\027�226*\000\000\000�--Type <return> to continue, or q <return> to quit---
\033�226*\000\000\000\210 �226*\000\000\0000%�226*\000\000\000��226*\000\000\000\000\020\020\227*\000\000\000\024\020\227",
"*\000\000\000P\031\020\227*\000\000\000\035\020\227*\000\000\000\"\020\227*\000\000\000H'\020\227*\000\000\000+\020\227*\000\000\0000\020\227*\000\000\000P5\020\227*\000\000\000t \227*", '\0' <repeats 11 times>, "b\032@",
"\000\000\000\000\020�\177\000\000\000b\032@\000\000\000\000\000x�\000\000\000\000\000�\177\000\000\000Y�0238\000\000\000�\177\000\000\000\224�0238", '\0' <repeats 11 times>, "h�\000\000\000\000\000�",
"\177\000\000\000Y�0238\000\000\000\000�\177\000\000\000\224�0238", '\0' <repeats 11 times>, "X�\000\000\000\000\000�\177\000\000\000Y�0238\000\000\0000�\177\000\000\000\224�0238\000\000\000\000\000\000",
"\000\000\000\000H�\000\000\000\000\000�\177\000\000\000Y�0238\000\000\000\001\000\000\000\177\000\000\000t \227*\000\000\0000�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000",
"\177\000\000\000\000p \227*\000\000\000�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000@:\020\227*\000\000\000\000�\177", '\0' <repeats 11 times>, "�",
"\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000P5\020\227*\000\000\0000�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\0000\020\227*\000\000\000`�",
"\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000+\020\227*\000\000\000\220�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000",
"\177\000\000\000H'\020\227*\000\000\000�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000\"\020\227*\000\000\000�\177", '\0' <repeats 11 times>, "�",
"\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000\035\020\227*\000\000\000 �\177"---Type <return> to continue, or q <return> to quit---
, '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000P\031\020\227*\000\000\000P�",
"\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000\024\020\227*\000\000\000\200�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000",
"\177\000\000\000\000\020\020\227*\000\000\000�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000��226*\000\000\000�\177", '\0' <repeats 11 times>, "�",
"\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\0000%�226*\000\000\000\020�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000\210 �226*\000\000\000@�",
"\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000�033�226*\000\000\000p�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000",
"\177\000\000\0008\027�226*\000\000\000�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000\230\022�226*\000\000\000�\177", '\0' <repeats 11 times>, "�",
"\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000\r�226*\000\000\000\000�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000X\t�226*\000\000\0000�",
"\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000\004�226*\000\000\000`�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000",
"\177\000\000\000\000\000�226*\000\000\000\220�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000hY\225\226*\000\000\000�\177", '\0' <repeats 11 times>, "�",
"\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000T\225\226*\000\000\000�\177", ---Type <return> to continue, or q <return> to quit---
'\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000\000P\225\226*\000\000\000 �",
"\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000`\t\225*\000\000\000P�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000",
"\177\000\000\000\004\225*\000\000\000\200�\177", '\0' <repeats 11 times>, "�\177\000\000\000�231�0238\000\000\000\001\000\000\000\177\000\000\000\000\000\225*\000\000\000�\177", '\0' <repeats 11 times>, "�",
"\177\000\000\000\037�0238\000\000\000\001\000\000\000\177\000\000\000\0010\227*\000\000\000�\020\227*\000\000\000��0238\000\000\000�\177\000\000\000�231�023u\032i\t\002\000\000\000\177\000\000\000H\025�225*\000\000\000\000\000\000",
'\0' <repeats 12 times>, "t0�0238\000\000\000\210�\0238\000\000\000\210)�0238\000\000\000-\000\000\000\000\000\000\000H�\227*\000\000\000@�\227*\000\000\000�\177\000\000\000`\005�0238\000\000\000�006",
"\000\000\000\000\006�0238\000\000\000p�\177\000\000\0005!�0238\000\000\000\000�\177\000\000\000�\177\000\000\000�006\000\000\000\000\000\006�0238", '\0' <repeats 11 times>, "\236x�0238\000\000\000@�\227",
"*\000\000\000\000\000\000\0008", '\0' <repeats 11 times>, "\001\000\000\000*\000\000\000�\177", '\0' <repeats 11 times>, "�\177\000\000\000\000\000\000\000\001\000\000\000@�\227*\000\000\000�\�0238\000\000\000\210�",
"\177\000\000\000hS�0238", '\0' <repeats 11 times>, "�231�0238\000\000\000\001\000\000\000\000\000\000\000H\205i\225*\000\000\0000�\177", '\0' <repeats 19 times>, "�231�0238\000\000\000\001\000\000",
"\000\000\000\000\037�0238\000\000\000\005\000\000\000\000\000\000\000\001\000\000\000\000\000\000\000�201 \227*\000\000\000��0238\000\000\000h�\0238\000\000\000t \227u\032i\t\002\000@;\000\000\000hS�0238\000\000\000\000\000\000",
"\000\000\000\000\003\000\000\000\000\000\000\000t0�0238\000\000\000\210�\0238\000\000\000\210)�0238\000\000\000-\000\000\000\000\000\000\000H�\227*\000\000\000\030�\227*\000\000\000P�\177\000\000\000X)\0248\000\000\000\232\a",
"\000\000\000\000i,\0248\000\000\000`\005�0238\000\000\000\000X\225\226*\000\000\000\220�\177\000\000\000P�\177\000\000\000\232\a\000\000\000\000i,\0248", '\0' <repeats 11 times>, "\236x�0238\000\000\000\030�\227",
"*\000\000\000\001\000\000\0008", '\0' <repeats 11 times>, "\001", '\0' <repeats 11 times>, "\177\000\000\000\230\036@", '\0' <repeats 17 times>, "\001\000\000\000\030�\227*\000\000\000\000X\225\226*\000\000\000�",
"\177\000\000\000\037�0238\000\000\000�0\227*\000\000\000\0010\227*\000\000\000�\020\227*\000\000\000��0238\000\000\000�201 \227*\000\000\000\037�0238\000\000\000\002\000 \227*\000\000\000\0010\227*\000\000\000�\020\227",
"*\000\000\000��0238\000\000\000t0�0238\000\000\000��0238\000\000\000\002\000�0238\000\000\000-\000\000\000t)\222\b\002\000\000\000\000\000\000\000��0238", '\0' <repeats 11 times>, "\210�\023t)\222\b\002\000\223\026",
"8\000\000\000o\221\0268", '\0' <repeats 11 times>, "-\000\000\000\000\000\000\000\205\223\0268\000\000\000��0238\000\000\000xC\220\0268\000\000\000\037�0238\000\000\000\002\0000\227*\000\000\000\0010\227*\000\000\000\t\220\031",
"8\000\000\000��0238\000\000\000\205\223\0268\000\000\000o\221\026u\032i\t\002\000\220\0268\000\000\000-", '\0' <repeats 15 times>, "0�\227\000\000\000\000t0�0238\000\000\000\210�\0238\000\000\000\210)�023", "8\000\000\000-\000\000\000\000\000\000\000H�\227*\000\000\000�\227*\000\000\000`�\177\000\000\000\211u�0238\000\000\000y:<\a\000\000\000\000\037�0238", '\0' <repeats 11 times>, "\037�0238\000\000\000\204\n�023",
"8\000\000\000\001\000\000\000\000\000\000\000�201 \227*\000\000\000��0238\000\000\000\002\000d\226*\000\000\000-\000\000\000u\032i\t\002", '\0' <repeats 23 times>, "o\221\026\000\000\000\000t0�023",
"8\000\000\000\210�\0238\000\000\000\210)�0238\000\000\000-\000\000\000\000\000\000\000H�\227*\000\000\000\210�\227*\000\000\000\020�\177\000\000\000\037�0238\000\000\000ta�003\000\000\000\000\0010\227*\000\000\000�\020\227",
"*\000\000\000��0238\000\000\000P�\177\000\000\000\020�u\032i\t\002\000�003\000\000\000\000@�\225*",
'\0' <repeats 11 times>, "\236x�023\000\000\000\000t0�0238\000\000\000\210�\0238\000\000\000\210)�023",---Type <return> to continue, or q <return> to quit---
"8\000\000\000-\000\000\000\000\000\000\000H�\227*\000\000\000�0\227*\000\000\000�\177\000\000\0000\a@\000\000\000\000\000\216w\001\000\000\000\000\220\032@\000\000\000\000\000x�\177\000\000\000�\�0238\000\000\000�",
"\177\000\000\000�\177\000\000\000\216w\001\000\000\000\000\220\032@", '\0' <repeats 13 times>, "\236x�0238\000\000\000�0\227*\000\000\000\001", '\0' <repeats 15 times>, "\001\000\000\000*\000\000\000\025\000\000",
"\000\000\000\000�i\226*\000\000\000\020\220\0268\000\000\000\000\000\000\000\001\000\000\000�0\227*\000\000\000�\�0238\000\000\000\b�\177\000\000\000Y�0238\000\000\000\b\000\000\000\000\000\000\000H\237\t\226*\000\000\000Y�023",
"8\000\000\000@\006\003\0248\000\000\000\020\004\000\000\000\000\000\000\200\215U\226*\000\000\000H\237\t\226*\000\000\000Y�0238\000\000\000�\177", '\0' <repeats 11 times>, "@L�0238\000\000\000C&@\000\000\000\000\0002@"}}
(gdb)
As usually in 64bit problems, I am lost...
Markus
