[GRASS-dev] [bug #5454] (grass) ps.map scaling not correct when
projection units are feet
Hamish
hamish_nospam at yahoo.com
Tue Jan 30 01:59:08 EST 2007
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5454
> Subject: ps.map scaling not correct when projection units are feet
fixed in 6.3-CVS and 6.2 release branch. Also fixes bug #3096.
outstanding issue, due to :
> > > and a PROJ_UNITS file of:
> > > unit: US survey foot
> > > units: US survey foots
Hamish:
> > foots? ^^^^^^^
Tom:
> That's what it picked on its own. I think the function that chooses
> the plural just tacks an "s" on the end except under very specific
> conditions.
lib/gis/proj2.c, proj3.c have some pluralizing magic, but in this case
that's the way it's stored in the PROJ_UNITS file created from EPSG code
#2258.
G63> g.proj -p
-PROJ_INFO-------------------------------------------------
proj : tmerc
datum : nad83
ellps : grs80
lat_0 : 31
lon_0 : -106.25
k : 0.999900
x_0 : 500000.0001016001
y_0 : 0
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : US survey foot
units : US survey foots
meters : 0.3048006096012192
the only place I see "US survey foot" in the code is one line in
lib/proj/unit_of_measure.csv.
Create new locn from EPSG code is in general/g.proj/output.c,
but I don't really follow it.
The string gets passed to the ps.map mapinfo output, so it matters.
Work-around: edit the PERMANENT/PROJ_UNITS file by hand.
Hamish
ps- should we undelete lib/init/make_location_epsg.sh.in and move it into
tools/ as a useful utility script?
