[GRASS-dev] Re: gui startup bug (new locn by epsg code)
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Jan 31 05:55:10 EST 2007
On Tue, 30 Jan 2007, Glynn Clements wrote:
> Paul Kelly wrote:
>> How do you propose it is fixed? It is arguable IMHO that the problem is
>> not in g.proj. It will only interactively prompt if *partially complete*
>> datum information is passed to it. If the GUI passes projection
>> information that has been pre-processed so the datum part is OK, then it
>> will not interactively prompt. This was discussed in an earlier thread.
> Yes, and I proposed a solution: replace the call to
> GPJ_ask_datum_params() with either a call to G_fatal_error() or some
> form of error indication (e.g. "return -1"). Assuming the availability
> of a terminal to obtain missing data from the user is a bug in
> GPJ_osr_to_grass().
> Unless someone else proposes an alternative solution soon, I intend to
> change GPJ_osr_to_grass() to simply ignore the "interactive"
> parameter; if datum parameters are missing, you get the defaults; it
> will be up to the user to fix it afterwards. That approach has the
> advantage that it doesn't require any changes to calling programs
> (g.proj, v.in.ogr, r.in.gdal).
If it has to be done I wouldn't like to see the functionality to choose
datum parameters from the tables in GRASS relegated to only g.setproj. I
was thinking along the lines of adding a new "interactive" flag to g.proj.
If this flag was specified along with -p, -j, -w or -c it would prompt as
at present if datum information was incomplete; if used along with the -d
flag then after reporting the datum information it would ask the user if
he/she wished to change the parameters.
And every other place that calls GPJ_osr_to_grass() or GPJ_wkt_to_grass()
(I'm thinking of r.in.gdal and v.in.ogr and g.proj without the
-i/interactive flag specified) would set the interactive flag in the
function to 0.
> It isn't ideal, but it's a lot less non-ideal than assuming that a
> terminal is available.
> Also, note that g.proj already silently uses the default parameters if
> you read the settings from stdin with wkt=- or proj4=-, so it isn't as
> if we currently *insist* upon full datum information being provided.
Good point; I'd forgotten about that.
> Glynn Clements <glynn at gclements.plus.com>
