[GRASS-dev] time to release 6.2.2
Mon Jul 2 15:22:05 EDT 2007
Markus Neteler wrote:
> >>> I still think it is a good idea to include the date of releases in the
> >>> tag name, less confusion that way, e.g. release_20070702_grass_6_2_2 -
> >>> what do you think? Or is there any other way of telling from CVS on
> >>> what date the tag was created?
> >> I don't know but I remember that someone (Glynn?) suggested to NOT
> >> include the
> >> date so that it wasn't done any more.
> > Well that's fine then if it has been discussed - I guess I just missed
> > that when it happened but there were I'm sure good reasons for it
> > then. FWIW my reasons for keeping with the old-style tags would be (a)
> > less likely to create a tag by accident as you're putting a meaningful
> > date into it and have to stop and think about that and (b) easy quick
> > reference looking back through the web-based CVS browser as to the
> > dates of the earlier releases.
> > But neither of those are particularly important. Good luck in shifting
> > the tag!
> I found this documentation:
> http://cvsnt.org/manual/html/Modifying-tags.html
> Anyone with experience...?
If you want to discard the existing grass_6_2_2 tag and tag the
current version:
	cvs rtag -d grass_6_2_2 grass6
	cvs tag -c release_20070702_grass_6_2_2
If you just want to rename the existing tag, ignoring any updates on
the branch:
	cvs rtag -r grass_6_2_2 release_20070702_grass_6_2_2 grass6
