[GRASS-dev] how to deal with the @mapset in scripts?
Maciej Sieczka
tutey at o2.pl
Tue Jul 3 10:58:08 EDT 2007
Glynn Clements wrote:
> Why do you actually need to use g.findfile? In most cases, you should
> just pass the map name directly to the command, and let the command
> handle the checking.
It's better to check if the output exists in the initial stage of my
script, than to let it run for an hour and then fail with an error that
the output already exists in the end.
Maciek
