[GRASS-dev] r.recode workaround
Wed Jul 4 04:16:03 EDT 2007
Michael Barton wrote:
> I've identified why r.recode was not recognizing the last term of the
> last recode rule. It needs a newline (\n) after the last recode rule
> in order to read all terms.
> I don't think it worked like that before, but it is not a problem once
> you know what to do. I've modified both the wxPython and TclTk GUI's
> for rules entry to add a newline to r.recode rules and it all works
> fine.
The first task is to change the fgets() call in r.recode/read_rules.c to
G_getl2(). Then see if the bug is still there. G_getl2() doesn't store the
newline but fgets() does.
      if (isatty(fileno(fp))) fprintf (stderr,"> ");
      if (!fgets(buf,1024,fp)) return nrules;
      buf[strlen(buf)-1] = '\0';
//    ^^^ chops off the newline char using a blind brute force method.
//        if fgets() ended because of EOF, the last char is real data.
      for (n=0;buf[n];n++)
           if(buf[n] == ',')
              buf[n] = ' ';
      G_strip(buf);
      if (*buf == 0) continue;
      if (*buf == '#') continue;
      if (strcmp(buf, "end") == 0) break;
Hamish
