[GRASS-dev] d.rast.edit in wxgrass
Wed Jul 4 05:08:24 EDT 2007
Michael wrote:
> >> 2nd splitting that allows for multiple d.* commands to be separated
> >> by semi-colons. This may or may not be a good idea in the end, but
> >> I thought I'd see how it worked out.
Paul:
> > Shell uses semi-colons. But you could you not just enter the two
> > commands separately one after the other? I suppose if it was
> > something that would take a long time to draw then that would be
> > slow.
Michael:
> The problem is that you need a defined separator that indicates where
> one command AND its arguments stop and another one starts. You could
> perhaps look for another "d." string, but a defined separator is
> easier to use and perhaps more reliable.
If you don't like semi-colons, would the newline char work?
Hamish
