[GRASS-dev] Postgres DB driver links to TclTk?
Glynn Clements
glynn at gclements.plus.com
Wed Jul 4 08:28:47 EDT 2007
Markus Neteler wrote:
> > I was poking around and noticed that the GRASS Postgres DB driver
> > links the TclTk libraries. It also has the the TclTk include dirs in
> > the CFLAGS. But it doesn't appear to use any TclTk functions. None
> > of the other DB drivers uses TclTk.
> Indeed:
> cd grass63/dist.x86_64-unknown-linux-gnu/driver/db/
> ldd pg | tr -s ' ' ' ' | cut -d' ' -f1 | sort
> /lib64/ld-linux-x86-64.so.2
> libcom_err.so.2
> libcrypto.so.4
> libcrypt.so.1
> libc.so.6
> libdl.so.2
> libgrass_datetime.so
> libgrass_dbmibase.so
> libgrass_dbmidriver.so
> libgrass_dbstubs.so
> libgrass_gis.so
> libgrass_sqlp.so
> libgssapi_krb5.so.2
> libk5crypto.so.3
> libkrb5.so.3
> libm.so.6
> libnsl.so.1
> libpq.so.4
> libpthread.so.0
> libresolv.so.2
> libssl.so.4
> libtcl8.4.so
> libtk8.4.so
> libX11.so.6
> libz.so.1
> > mistake?
> It doesn't seem to be GRASS:
> cd grass63/dist.x86_64-unknown-linux-gnu/lib/
> for i in `ls -1 *.so | grep -v cvs` ; do echo "======= $i:" ; ldd $i ;
> done | grep tcl
> -> nothing
> No idea where it creeps in (didn't check the system libs).
It's in db/drivers/postgres/Makefile:
14 EXTRA_CFLAGS = $(PQINCPATH) $(TCLINCDIR) $(TKINCDIR)
26 $(CC) $(LDFLAGS) -o $@ $(ARCH_OBJS) $(FMODE_OBJ) $(PQLIBPATH) $(LIBES) $(TCLTKLIBPATH) $(TCLTKLIBS) \
Those options were added in:
revision 1.4
date: 2003/01/15 15:36:24; author: radim; state: Exp; lines: +6 -3
parser for database, user/password dialog
No idea why; I'll remove them.
