[GRASS-dev] Re: [GRASS-CVS] carlos: grass6/raster/r.his main.c,
2.6, 2.7
Carlos Dávila
cdavilam at jemila.jazztel.es
Fri Jul 6 11:26:31 EDT 2007
Martin Landa escribió:
> Ciao Carlos,
> I am not sure too (it is the question for native speakers...)
> http://www.nabble.com/message-standardization-on-wiki-tf3559274.html#a9939189
> "Cannot open raster map" X "Unable to open raster map"
> Martin
OK, now I see. I'm afraid we have a contradiction in wiki, as in
"Standard messages sandbox > Raster messages" we have "Cannot open
raster map <%s>" and in "Messages discussion > G_open_cell_old" proposed
standard response is "Unable open raster map <%s>", so we have to choose.
Any help from native speakers is welcome.
Regards
Carlos
> 2007/7/6, Carlos Dávila <cdavilam at jemila.jazztel.es>:
>> Hi,
>> just a stupid note
>> - G_fatal_error(_("Unable to open raster map [%s]"),
>> name_h);
>> + G_fatal_error(_("Unable to open raster map <%s>"),
>> name_h);
>> wouldn't be better to use "Cannot open raster map <%s>"?, see wiki and
>> discussion in grass-dev mailing list...
>> For sure I may be wrong, but I've been revising wiki and lists (dev and
>> translations) and I can't see where it is suggested to use cannot
>> instead of
>> unable to.
>> What I found is:
>> >From wiki
>> First letter should be capitalized
>> Use the present tense (cannot instead of could not; better: unable
>> to) ...
>> G_open_cell_old "Unable to open raster map <%s>" >From translation
>> list:
>> > > > I would prefer not using "Cannot...". It's bad grammar. I
>> would much
>> > > > prefer "Unable to..." or something to that effect.
>> > > While I can see your point, that construction is quite common in
>> error
>> > > messages, e.g.:
>> > > $ ls -l foo
>> > > ls: cannot access foo: No such file or directory
>> > > Neither "cannot ..." nor "unable to ..." form complete sentences.
>> > > If you're concerned about grammar, you can provide an explicit
>> subject
>> > > ("The program cannot ..."), or use the third person (e.g. "The file
>> > > cannot be found").
>> > > Personally, I don't have a problem with just omitting the subject.
>> > Point taken. I was really referring to the usage of "Cannot". Some
>> > dictionaries do not recognize it as 'real word', yet others (that are
>> > generally more progressive with slang and contractions) say that it
>> > should replace "can not" in modern English.
>> > It's a non-problem. In modules I've [re]written, I've used "Unable
>> to",
>> > but I can go back and change them for consistency.
>> It seems to me that "Unable to" is the most impartial form.
>> Martin
>> PS: Thanks to Carlos for this hard job!
>> Thanks to all of you for the support.
>> grass-dev at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass-dev
