[GRASS-dev] [grass-code P][441] v.in.gns does fails to import data
grass-codep at wald.intevation.org
Fri Jul 6 12:21:33 EDT 2007
code P item #441, was opened at 2007-07-06 16:21
Status: Open
Priority: 3
Submitted By: Artur Wroblewski (wrobell)
Assigned to: Nobody (None)
Summary: v.in.gns does fails to import data
Patch status: None
Patch type: fix
GRASS component: vector
GRASS version: 6.2.1
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
running v.in.gns to import pl or nl data from GNS i am getting
an error
ERROR: Length of column 19 (2) is less than maximum value length (3)
this is about LC column described at
http://earth-info.nga.mil/gns/html/help.htm
above specification says that LC column consists of 3 characters
but v.in.gns defines it as 2 character string.
patch attached.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=205&aid=441&group_id=21
