[GRASS-dev] Possible error in r.flow error message
Carlos Dávila cdavilam at jemila.jazztel.es
Tue Jul 10 13:45:20 EDT 2007
Helena Mitasova escribió:
> On Tue, 2007-07-10 at 17:47 +0200, Carlos Dávila wrote:
>> I have tested r.flow looking for messages to standardize. I gave a non
>> existing input elevation raster map, so I waited "Cannot find file %s"
>> but error message is "out of memory". Is it the right behaviour? Does it
>> check memory before looking for the input map? If so, why doesn't it get
>> memory?
> are you sure the file that you gave it was indeed non-existing?
> I tried it and it gave me the right message:
> GRASS 6.3.cvs > r.flow elevin=junk dsout=dsdtest
> Reading input files: elevation
> ERROR: Cannot find file junk
> Helena
Yes, sure.
GRASS 6.3.cvs (Extremadura_h29):~ > r.flow elevin=junk dsout=dsdtest
ERROR: G_calloc: sin memoria (out of memory)
May be I need to make distclean, but I have no time now to recompile.
Send result later.
