[GRASS-dev] Possible error in r.flow error message
Carlos Dávila cdavilam at jemila.jazztel.es
Wed Jul 11 04:47:09 EDT 2007
Carlos Dávila escribió:
> Helena Mitasova escribió:
>> On Tue, 2007-07-10 at 17:47 +0200, Carlos Dávila wrote:
>>> I have tested r.flow looking for messages to standardize. I gave a
>>> non existing input elevation raster map, so I waited "Cannot find
>>> file %s" but error message is "out of memory". Is it the right
>>> behaviour? Does it check memory before looking for the input map? If
>>> so, why doesn't it get memory?
>> are you sure the file that you gave it was indeed non-existing?
>> I tried it and it gave me the right message:
>> GRASS 6.3.cvs > r.flow elevin=junk dsout=dsdtest
>> Reading input files: elevation
>> ERROR: Cannot find file junk
>> Helena
> Yes, sure.
> GRASS 6.3.cvs (Extremadura_h29):~ > r.flow elevin=junk dsout=dsdtest
> ERROR: G_calloc: sin memoria (out of memory)
> May be I need to make distclean, but I have no time now to recompile.
> Send result later.
Still the same problem after make distclean and cvs update.
