[GRASS-dev] Re: [GRASS-user] GRASS 6.3 Installation Woes on OS X
Michael Barton
michael.barton at asu.edu
Wed Jul 11 21:26:03 EDT 2007
If you have a .grassrc6 file that has a set gisdbase, location, and/or
mapset (e.g., from using GRASS previously) and then you delete or rename any
of the above, GRASS init.sh will generate an error and GRASS will crash on
launch with the error message below.
The only fix is to either make the gisdbase, location, or mapset directory
that is listed in .grassrc6, or directly edit .grassrc6 to change or remove
the offending line.
Init.sh needs to trap this kind of error--or maybe better just ignore it. If
any of these files is not present, GRASS should simply go to either a) the
initial text based startup screen if the text interface or no interface is
selected in .grassrc6, or b) go to the GUI for selecting
gisdbase/location/mapset as if the gisdbase/location/mapset line was missing
from .grassrc6. In any case this should not cause a crash.
Michael
ERROR ON STARTUP WITH INCORRECT LOCATION SET IN .GRASSRC6
access: No such file or directory
ERROR: LOCATION << /Users/Shared/grassdata/test6 >> not available
File
"/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gis_set.py",
line 749, in <module>
GRASSStartUp = StartUp(0)
File
"/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packag
es/wx-2.8-mac-ansi/wx/_core.py", line 7757, in __init__
self._BootstrapApp()
File
es/wx-2.8-mac-ansi/wx/_core.py", line 7354, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File
line 740, in OnInit
StartUp = GRASSStartup(None, -1, "")
File
line 463, in __init__
self.__set_properties()
File
line 515, in __set_properties
self.lblocations.SetSelection(self.listOfLocations.index(location))
ValueError: list.index(x): x not in list
/Users/Shared/grassdata/test6/PERMANENT/.gislock: No such file or directory
ERROR: /Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/lock:
cmbarton is currently running GRASS in selected mapset (file
/Users/Shared/grassdata/test6/PERMANENT/.gislock found). Concurrent use not
allowed.
logout
[Process completed]
On 7/11/07 10:41 AM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
> On Jul 11, 2007, at 12:25 PM, Ryan Rosario wrote:
>> Thanks. All I have seen is .grassrc6 but that must have been from
>> Lorenzo's build. To get a similar environment I just created a
>> grass directory under /Users/ryan and then entered /Users/ryan/
>> grass into the GIS Data Directory field. I no longer get the error
>> I asked about.
>> Another user recommended creating my own .grassrc6 file which has
>> apparently worked for other users, but it seems that my way works
>> as well (both methods are probably doing the same thing). I
>> downloaded the Spearfish dataset and all appears good as new.
> The .grassrc6 file is (it should be) created automatically the first
> time you run GRASS. I'm not sure, but it may require a successful
> location/mapset selection/creation - ie you get the main GRASS
> command prompt.
> There is no need to create .grassrc6 before running GRASS. Or to
> edit it after creation, GRASS' g.gisenv maintains it.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
