[GRASS-dev] GRASS 6.3 on Cygwin
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Sat Jul 14 12:00:20 EDT 2007
Did anyone here try to get a recent version of GRASS CVS running under
Cygwin?
I got GDAL and GRASS to compile just fine, but when I want to start ANY
GRASS module that uses the GDAL libs directly or get linked to Vlib
which in turn is linked to GDAL.
I get nothing at all. Really: nothing at all, no error message, nothing.
Just get kicked to the prompt again. --help does not provoke a reaction,
neither does any other option. It seems that the modules just die
silently. Great.
GDAL itself seems to work fine. I can e.g. use ogr2ogr w/o problems.
I tried all GDAL versions from 1.3.1 to 1.4.2 with GRASS support built
in and using the gdal-grass plugin. Nothing.
I tried down and upgrading the binutils to several different versions.
Doesn't help.
I tried compiling absolutely minimal versions of both GRASS and GDAL.
No luck, either.
How hard can it be to get a recent version of GRASS to SOMEHOW run under
Windows?
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
