[GRASS-dev] [grass-code I][431] g.copy segmentation fault
Volker Wichmann
wichmann at laserdata.at
Wed Jul 25 03:22:20 EDT 2007
Glynn Clements wrote:
> You will need to provide more detailed information, i.e. the complete
> backtrace at the point of the segfault and the values of any relevant
> variables.
I did a backtrace, placed a break point a few lines before the crash and
did a re-run. Here is the output:
Starting program: /usr/local/grass-6.3.cvs/bin/g.copy rast=last.min,test5
[Thread debugging using libthread_db enabled]
[New Thread -1208260912 (LWP 4913)]
Copy raster <last.min at PERMANENT> to current mapset as <test5>
[Switching to Thread -1208260912 (LWP 4913)]
Breakpoint 1, do_copy (n=0, old=0x897c270 "last.min",
mapset=0x897c2b8 "PERMANENT", new=0x897c280 "test5") at do_copy.c:31
31 hold_signals(1);
(gdb) next
32 if ( G_strcasecmp (list[n].alias, "vect") == 0 ) {
(gdb) next
40 for (i = 0; i < list[n].nelem; i++)
(gdb) next
35 G_warning ("Cannot copy <%s> to current mapset as <%s>",
(gdb) next
42 G__make_mapset_element (list[n].element[i]);
(gdb) next
43 G__file_name (path, list[n].element[i], old, mapset);
(gdb) next
44 if (access (path, 0) != 0)
(gdb) next
52 G__file_name (path2, list[n].element[i], new, G_mapset());
(gdb) next
53 if ( recursive_copy(path, path2) == 1 )
(gdb) print path
$1 =
"/data/grassdb/demo/PERMANENT/cell/last.min\000\217\221\000\001\000\000\000\b\000\000\000��������\000\000\000\000\200s�\000��\227\b\003\000\000\000\000\000\000\000���\000\000\000\000\000Q���",
'\0' <repeats 16 times>,
"�o�\000\000\000\000\000ص\227\b\001\000\000\000\000\000\000\000\002\000\000\000ص\227\b���\000����8���\202B\025\000�{�\000ص\227\b
\000\000\000�xP�\000\000\000\000ص\227\b\202��\000K֨\000\202��\000
\201�\000Q\000\000\000L\201�\000\000\000\000\000"...
(gdb) print path2
$2 = "/data/grassdb/demo/PERMANENT/cell/test5\000\227\b\001\000\000\000
\000\000\000\002\000\000\000�輿3d.view:3dview:3D viewing parameters:3D
view parameters\000\000n files\000\000���\217\221\000x\221��L鼿\200鼿�h
\220\000\000\000\000\000kI \024\000㰬\000�\217\221\000�'���q�\000nȫ\000\
f\226\227\b\000\000\000\000
\212\224\227\b�o�\000W\030\031\000\000\000\000\000T�"...
(gdb) next
59 if (G_verbose() == G_verbose_max())
(gdb) next
(gdb) next
Program received signal SIGSEGV, Segmentation fault.
do_copy (n=0, old=0x897c270 "last.min", mapset=0x897c2b8 "PERMANENT",
new=0x897c280 "test5") at do_copy.c:40
(gdb) print i
$3 = 0
(gdb) print n
$4 = 0
(gdb) print list[n].nelem
$5 = 8
(gdb) print path
$6 =
(gdb) print path2
$7 = "/data/grassdb/demo/PERMANENT/cell/test5\000\227\b\001\000\000\000
(gdb) bt full
#0 do_copy (n=0, old=0x897c270 "last.min", mapset=0x897c2b8 "PERMANENT",
i = 0
ret = <value optimized out>
path =
path2 =
result = 0
#1 0x080493eb in main (argc=2, argv=0xbfbcf1a4) at copy.c:95
n = <value optimized out>
mapset = 0x897c2b8 "PERMANENT"
module = (struct GModule *) 0x199b90
parm = (struct Option **) 0x897b5d8
p = <value optimized out>
---Type <return> to continue, or q <return> to quit---
to = 0x897c280 "test5"
result = 0
(gdb) continue
Continuing.
Program terminated with signal SIGSEGV, Segmentation fault.
Seems to me that path and path2 are corrupted?
What I'm also unsure about is why line 35 is entered while stepping
through the code - a gdb issue I can forget about?
Thanks,
Volker
