[GRASS-dev] d.font -l: please sort alphabetically
Markus Neteler neteler at itc.it
Thu Jul 26 07:50:03 EDT 2007
Glynn Clements wrote:
> Markus Neteler wrote:
>> I have tried but both -l and -L don't report anything (any more).
>> I didn't run "make distclean" if that matters.
> It matters.
> The architecture of the graphics subsystem is such that adding new
> operations invariably requires substantial re-compilation. Unless
> you're especially familiar[1] with the graphics subsystem, it's easier
> to just start from scratch with "make distclean" than to figure out
> what needs to be re-compiled.
> [1] Actually, even if you are familiar, it's easy to get bitten. I
> spent 10 minutes tracking down a problem caused by failing to run
> "make -C lib headers" (which copies include/* to dist.<arch>/include)
> after modifying include/graphics.h.
Also after full recompile, nothing yet. I am working on 64bit boxes
(RHEL4 and Mandriva2007.1).
Ah, found it through re-debugging!
static void read_freetype_fonts(int verbose)
        char **list;
        int count;
        int i;
        R__open_quiet();
        if (R_open_driver() != 0)
                return;
If the GRASS monitor isn't open, it silently exits at R_open_driver().
Maybe it should say that a monitor must be open (would be nice of course
to get it working also without monitor, but probably not possible?).
Markus
View this message in context: http://www.nabble.com/d.font--l%3A-please-sort-alphabetically-tf4138371.html#a11808978
Sent from the Grass - Dev mailing list archive at Nabble.com.
