[GRASS-dev] Re: grass-dev Digest, Vol 15, Issue 37
Massimiliano Cannata massimiliano.cannata at supsi.ch
Mon Jul 30 07:20:49 EDT 2007
Thanks Michael,
This example is really clear and easy to do.
In 2 minutes I added some new commands to my tcl/tk interface... :-)
Really useful!
Compliment.
Maxi
Maxi
Michael Barton wrote:
> Tom,
> If you want to play around with TclTk a bit, you could simply add a line or
> two in one of the currently existing menus (all in
> $GISBASE/etc/gm/gmmenu.tcl) to do a specific task. For example, you could
> add a menu entry that could have for its command: "v.surf.bspline
> input=wstation_temp raster=tempmap type=bicubic column=temp"
> This would take a file of vector weather station points named
> "wstation_temp", with an attribute column named "temp", and use bicubic
> interpolation to create a temperature surface named "tempmap"
> Here is a bit of script that could be inserted into the raster menu to add a
> submenu for doing weather-related raster modeling
> {separator}
> {cascad {[G_msg "Weather modeling"]} {} "" $tmenu {
>    {command {[G_msg "temperature surface"]} {} "bicubic interpolation
>            of weather station temperature data" {} -command {execute
>            v.surf.bspline input=wstation_temp raster=tempmap type=bicubic
>            column=temp }}
>    {separator}
>    {command {[G_msg "another menu entry"]} {} "put the help text here" {}
>            -command {execute GRASSCOMMAND }}
> {separator} inserts a line separating menu items
> {cascad... } creates a submenu
> {command...} creates a menu entry that starts a command.
> Maybe this can help you show how easy it is to make custom menu entries.
> Hope this is helpful.
> Michael
> On 7/27/07 10:23 AM, "grass-dev-request at grass.itc.it"
> <grass-dev-request at grass.itc.it> wrote:
>> Send grass-dev mailing list submissions to
>> grass-dev at grass.itc.it
>> To subscribe or unsubscribe via the World Wide Web, visit
>> http://grass.itc.it/mailman/listinfo/grass-dev
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> grass-dev-owner at grass.itc.it
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of grass-dev digest..."
>> Today's Topics:
>>    1. Re: r.terraflow on Mac OS X 10.4.9 (Michael Barton)
>>    2. Re: r.terraflow on Mac OS X 10.4.9 (Helena Mitasova)
>>    3. Re: [GRASS-user] GRASS "custom" applications (Thomas Adams)
>>    4. Re: [GRASS-user] Re: [GRASS-dev] GRASS "custom" applications
>>       (Thomas Adams)
>>    5. Re: Re: gis.m: font selection in module panels (Paul Kelly)
>>    6. Re: Re: [GRASS-user] GRASS "custom" applications (Paul Kelly)
> Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070730/f0367494/massimiliano.cannata.vcf
