[GRASS-dev] Re: [GRASS-user] circle surrounding neighbors
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Tue Jul 31 05:05:09 EDT 2007
> > > Sorry, I am a beginner... what shall I do with this gather-circle.c?
> > Replace raster/r.neighbors/gather.c with the new file, re-compile,
> > install the modified r.neighbors as e.g. r.neighbors.circle.
> > If you don't have the source code or can't figure out how to make the
> > necessary changes, you'll need to wait until someone integrates it
> > into GRASS.
> FWIW, I've added a -c flag to r.neighbors to use a circular
> neighborhood rather than a square.
great!
> I'm unsure as to whether the test should be < or <=. It's currently
> <=, but that gives "spikes" (single cells) at the four edges. Using <
> would give "flats", and would always omit the outermost row/column of
> pixels. Maybe there should be a +0.5 in the distance calculation?
then the command works like
r.neighbors -c input=name output=name method=average size=5
and the output would be the average of values in a ring of 5x5 around the
center pixel, wouldn't it?
then I can drop my r.mapcalc script and close one old wish report related to
r.le but solved via r.neighbors
(http://www.intevation.de/rt/webrt?serial_num=2104&display=History) - thanks
a lot!
Martin
