[GRASS-dev] executing r.example
Juan Diego Giraldo Osorio
Juan.Giraldo at upct.es
Fri Jun 1 05:39:39 EDT 2007
Hi
Today I have ran the r.example code. Thanks to all.
However, I have several problems executing grass62:
- When I get in to grass, the program shows a (new!!!) interface. I
select the Mapset and Location, and when I do click on "Enter Grass",
the prompt shows this:
GRASS 6.2.1 (METEOSAT):~ > g.region: error while loading shared
libraries: libgdal.so.1: cannot open shared object file: No such file or
directory
-When I execute g.region...
g.region: error while loading shared libraries: libgdal.so.1: cannot
open shared object file: No such file or directory
- When I try to execute r.in.gdal...
GRASS 6.2.1 (METEOSAT):~ > r.in.gdal
r.in.gdal: error while loading shared libraries: libproj.so.0: cannot
I have the libgdal.so.1 in /usr/lib directory, and both files
(libgdal.so.1 and libproj.so.0) in /usr/local/lib. How can I overcome
these problems??
Thanks
Juan
