[GRASS-dev] wms in wxgrass?
Agustin Diez Castillo
Agustin.Diez at uv.es
Fri Jun 1 07:09:28 EDT 2007
same command I got a somewhat different error
All tiles downloaded successfully
r.in.gdalwarp -c 'input=/Users/Shared/grassdata/wms_download/
terraserver-drg_rural_1m_0.tiff' 'output=terraserver-drg'
'method=nearest' 's_srs=EPSG:4326'
gdalwarp -s_srs "EPSG:4326" -t_srs "PROJCS["Lambert Conformal
Conic",GEOGCS["grs80",DATUM["North_American_Datum_1983",SPHEROID
["grs80",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["degree",
0.0174532925199433]],PROJECTION
["Lambert_Conformal_Conic_2SP"],PARAMETER["standard_parallel_1",
34.33333333333334],PARAMETER["standard_parallel_2",
36.16666666666666],PARAMETER["latitude_of_origin",33.75],PARAMETER
["central_meridian",-79],PARAMETER["false_easting",
609601.22],PARAMETER["false_northing",0],UNIT["Meter",1]]" "/Users/
Shared/grassdata/wms_download/terraserver-drg_rural_1m_0.tiff" "/
Users/Shared/grassdata/nc_spm_05/user1/.tmp/regadiuet.prearq.uv.es/
16540.0warped.geotiff" -rn
ERROR 1: TIFFFetchDirectory:/Users/Shared/grassdata/wms_download/
terraserver-drg_rural_1m_0.tiff: Can not read TIFF directory count
ERROR 1: TIFFReadDirectory:/Users/Shared/grassdata/wms_download/
terraserver-drg_rural_1m_0.tiff: Failed to read directory at offset 0
ERROR 4: `/Users/Shared/grassdata/nc_spm_05/user1/.tmp/
regadiuet.prearq.uv.es/16540.0warped.geotiff' does not exist in the
file system,
and is not recognised as a supported dataset name.
On May 31, 2007, at 11:56 AM, Markus Neteler wrote:
>>> g.region rural_1m -p
>>> r.in.wms output=terraserver-drg
>>> mapserver=http://terraserver.microsoft.com/ogcmap6.ashx
>>> layers=DRG region=rural_1m format=tiff
>> Requesting 1 tiles.
>> Downloading tiles
>> Tile already downloaded
>> <html><head><title>OGCMap Test</title></head>
>> <body>
>> <h3>Service Exception Report</h3>
> vvv
>> <p>Found 1 errors</p>
>> <br>Unable to parse EPSG code 3358
>> </body></html>
>> Any idea?
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070601/b7f8535e/attachment.html
