[GRASS-dev] [grass-code P][416] print transformation matrix after running v.transform
grass-codep at wald.intevation.org grass-codep at wald.intevation.org
Sat Jun 2 18:29:03 EDT 2007
code P item #416, was opened at 2007-06-02 15:29
Status: Open
Priority: 3
Submitted By: Dylan Beaudette (dylan)
Assigned to: Nobody (None)
Summary: print transformation matrix after running v.transform
Patch status: None
Patch type: enhancement
GRASS component: vector
GRASS version: CVS HEAD
GRASS CVS checkout date, if applies (YYMMDD): 2007-0
Initial Comment:
small patch to v.transform/main.c and lib/vector/transform/transform.c which adds a flag to v.transform that will print the affine transformation matrix to stdout. This is a convinience enhancement for those who would like to inspect the matrix.
This patch has been tested, and appears to work well.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=205&aid=416&group_id=21
