[GRASS-dev] QGIS winGRASS blank space problem
Markus Neteler neteler at itc.it
Mon Jun 4 09:45:33 EDT 2007
Markus Neteler wrote:
> If he changes the path to not include a white space,
> he gets:
> $ v.rast.stats vector=CEA_riserve raster=CEA_slope colprefix=delete
>       0 [main] sh 5080 open_stackdumpfile: Dumping stack trace to
> sh.exe.stackdump
> An error occurred reading the input raster map resolution.
Update: the latter problem goes away if QGIS is *reinstalled* into a path
without white space. Remains the problem that it fails with white space
which is pretty common on MS-Windows systems (and apparently the
default of the QGIS installer).
Markus
View this message in context: http://www.nabble.com/QGIS-winGRASS-blank-space-problem-tf3865213.html#a10950079
Sent from the Grass - Dev mailing list archive at Nabble.com.
