[GRASS-dev] QGIS winGRASS blank space problem
Hamish
hamish_nospam at yahoo.com
Tue Jun 5 23:32:07 EDT 2007
Glynn Clements wrote:
> Hamish wrote:
> > > AFAICT, $SQLTMP is unnecessary. You can just as easily use a
> > > subshell with its output piped directly to db.execute; no need for
> > > a temporary file.
> > It is used in a loop- that would make it call db.execute nine times
> > per vector cat instead of once. db.execute is slow to start/stop, so
> > it is much faster to use a single call with $SQLTMP.
> That's incorrect.
> In terms of the number of times that db.execute is run, there is no
> difference between the existing code with a temporary file:
ah, I missed the "subshell", I thought you meant once per line.
still, a .tmp file is nice for debugging (even better if db.execute was
only run once), and it doesn't hurt much.
> Also, I would be inclined to clean up the above by looping over the
> column names i.e.:
> for var in n min max range mean stddev variance cf_var sum ; do
> eval val=\${$var}
> if [ $DBFDRIVER -eq 1 ] ; then
> col="`echo ${COLPREFIX}_${var}| cut -b1-10`"
> else
> col="${COLPREFIX}_${var}"
> fi
> echo "UPDATE $VECTOR SET ${col}=${val} WHERE cat=$i;"
> ) | db.execute database=$DB_DATABASE driver=$DB_SQLDRIVER
yes, but in that case you'd have to do something about cf_var:
> echo "UPDATE $VECTOR SET ${COLPREFIX}_cf_var=$coeff_var WHERE cat=$i;"
it was shortended from 'r.univar -g's coeff_var to work within DBF
column name width restrictions.
Hamish
