[GRASS-dev] broken polygon fills with d.vect render=l
Wed Jun 6 01:46:48 EDT 2007
I just threw up some new screenshots showing broken polygon fills with
d.vect render=l. What should not be filled, is partially filled.
Look near the end of the page:
 http://bambi.otago.ac.nz/hamish/grass/bugs/d.vect/
from those pics, and assuming we have to use the display library and not
the old libgis render functions, it appears that "c" would be a nicer
pick than "l", if the two bands of white at the edges could be corrected.
Hamish
