[GRASS-dev] Compile error on Kubuntu 7.04
Daniel Calvelo
dca.gis at gmail.com
Fri Jun 8 17:45:16 EDT 2007
Hi Isaac. You don't seem to have gettext installed. Try to apt-get
install gettext.
Daniel.
On 6/8/07, Isaac Ullah <isaac.ullah at asu.edu> wrote:
> Hi Listers,
> I am trying to compile GRASS-6.3.cvs on my recently installed Kubuntu
> (7.04, Fiesty Fawn) system. I've successfully compiled before on the same
> laptop (a toshiba r 10) under MEPIS 6 (also ubuntu based) and MEPIS 3.4.2
> (debian based). However this time I get the following error that I don't
> really understand:
> make[1]: Entering directory
> `/home/isaac/Desktop/grass63-cvs-source/locale'
> Creating translations (= 'make mo')
> make[2]: Entering directory
> grasslibs_ar.po: /bin/sh: msgfmt: not found
> grasslibs_cs.po: /bin/sh: msgfmt: not found
> grasslibs_de.po: /bin/sh: msgfmt: not found
> grasslibs_el.po: /bin/sh: msgfmt: not found
> grasslibs_es.po: /bin/sh: msgfmt: not found
> grasslibs_fr.po: /bin/sh: msgfmt: not found
> grasslibs_hi.po: /bin/sh: msgfmt: not found
> grasslibs_it.po: /bin/sh: msgfmt: not found
> grasslibs_ja.po: /bin/sh: msgfmt: not found
> grasslibs_ko.po: /bin/sh: msgfmt: not found
> grasslibs_lv.po: /bin/sh: msgfmt: not found
> grasslibs_mr.po: /bin/sh: msgfmt: not found
> grasslibs_pl.po: /bin/sh: msgfmt: not found
> grasslibs_pt_br.po: /bin/sh: msgfmt: not found
> grasslibs_ru.po: /bin/sh: msgfmt: not found
> grasslibs_sl.po: /bin/sh: msgfmt: not found
> grasslibs_tr.po: /bin/sh: msgfmt: not found
> grasslibs_vi.po: /bin/sh: msgfmt: not found
> grasslibs_zh.po: /bin/sh: msgfmt: not found
> grassmods_ar.po: /bin/sh: msgfmt: not found
> grassmods_cs.po: /bin/sh: msgfmt: not found
> grassmods_de.po: /bin/sh: msgfmt: not found
> grassmods_el.po: /bin/sh: msgfmt: not found
> grassmods_es.po: /bin/sh: msgfmt: not found
> grassmods_fr.po: /bin/sh: msgfmt: not found
> grassmods_hi.po: /bin/sh: msgfmt: not found
> grassmods_it.po: /bin/sh: msgfmt: not found
> grassmods_ja.po: /bin/sh: msgfmt: not found
> grassmods_ko.po: /bin/sh: msgfmt: not found
> grassmods_lv.po: /bin/sh: msgfmt: not found
> grassmods_mr.po: /bin/sh: msgfmt: not found
> grassmods_pl.po: /bin/sh: msgfmt: not found
> grassmods_pt_br.po: /bin/sh: msgfmt: not found
> grassmods_ru.po: /bin/sh: msgfmt: not found
> grassmods_sl.po: /bin/sh: msgfmt: not found
> grassmods_tr.po: /bin/sh: msgfmt: not found
> grassmods_vi.po: /bin/sh: msgfmt: not found
> grassmods_zh.po: /bin/sh: msgfmt: not found
> grasstcl_ar.po: /bin/sh: msgfmt: not found
> grasstcl_cs.po: /bin/sh: msgfmt: not found
> grasstcl_de.po: /bin/sh: msgfmt: not found
> grasstcl_el.po: /bin/sh: msgfmt: not found
> grasstcl_es.po: /bin/sh: msgfmt: not found
> grasstcl_fr.po: /bin/sh: msgfmt: not found
> grasstcl_hi.po: /bin/sh: msgfmt: not found
> grasstcl_it.po: /bin/sh: msgfmt: not found
> grasstcl_ja.po: /bin/sh: msgfmt: not found
> grasstcl_ko.po: /bin/sh: msgfmt: not found
> grasstcl_lv.po: /bin/sh: msgfmt: not found
> grasstcl_mr.po: /bin/sh: msgfmt: not found
> grasstcl_pl.po: /bin/sh: msgfmt: not found
> grasstcl_pt_br.po: /bin/sh: msgfmt: not found
> grasstcl_ru.po: /bin/sh: msgfmt: not found
> grasstcl_sl.po: /bin/sh: msgfmt: not found
> grasstcl_tr.po: /bin/sh: msgfmt: not found
> grasstcl_vi.po: /bin/sh: msgfmt: not found
> grasstcl_zh.po: /bin/sh: msgfmt: not found
> make[2]: *** [mo] Error 127
> make[2]: Leaving directory
> make[1]: *** [default] Error 2
> make[1]: Leaving directory
> make: *** [default] Error 2
> Does anyone know what the problem is here? I've never seen this error during
> any of the other times I've compiled GRASS... Any help would be greatly
> appreciated!
> Cheers,
> Isaac
> Isaac I Ullah, M.A.
> Archaeology PhD Student,
> ASU School of Evolution and Social Change
> Research Assistant,
> Mediterranean Landscape Dynamics Project
> ullah at archaeologist.com
> http://www.public.asu.edu/~iullah
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
-- Daniel Calvelo Aros
