[GRASS-dev] Re: [GRASSGUI] silly question - running a python script
Glynn Clements
glynn at gclements.plus.com
Sun Jun 10 16:28:43 EDT 2007
Michael Barton wrote:
> Here is what is currently there...
> if __name__ == "__main__":
> args = ""
> for arg in sys.argv:
> args += arg+" "
> try:
> if ( sys.argv[1] != "@ARGS_PARSED@" ):
> os.system("g.parser %s " % (args))
> except IndexError:
> os.system("g.parser %s" % (args))
> if sys.argv[1] == "@ARGS_PARSED@":
> main();
> I found an old email of yours I'd been saving (and couldn't initially find)
> that covers part of what needs to be done. Following that, I think it would
> change to...
> # No need to make a string here, right?
> # args = ""
> # for arg in sys.argv:
> # args += arg+" "
> try:
> os.execv("g.parser", [sys.argv[0]] + sys.argv)
> except IndexError:
> main();
> Is this correct or is it still missing something?
That looks about right.
Although the "try ... except IndexError" can be replaced with a length
check on sys.argv, i.e.:
if ( len(sys.argv) > 1 && sys.argv[1] != "@ARGS_PARSED@" ):
else:
main()
